RMW1112 RCA Microwave suddenly making knocking sound
trooper1954
BC,Canada
RMW1112
I have a two year old microwave that suddenly has started making a knocking sound in operation. If I remove the glass dish on which you place the food, the knocking disappears. Any one any idea what causes this and if its fixable? I suspect a bearing, but surely with limited use it should last more than two years?
Motor or turntable coupling?
There aren't too many parts associated with the turntable, the motor under the unit, the 'coupling' between the motor and tray and the tray itself.
It could be caused by an internal problem in the motor or the coupling slipping on the motor shaft or the tray slipping on the coupling. The tray itself probably isn't the cause.
and if its fixable?
If you can isolate the cause and locate replacement parts, it could be repairable. These cheap microwaves are however often difficult to find replacement parts for so bare that in mind. That's where the term 'throw away appliances' comes from.
If just the coupling was slipping on the motor shaft, if it couldn't be replaced it might be able to be glued or epoxied. The bottom line is soneone will actually need to look into it to determine the cause and what is required to correct it.
I suspect a bearing
There isn't usually anything like that in the tray mechanism.
Things break even within the first year warranty. Small, inexpensive appliances can be even worse.
JMO
Tray rollers
I forgot, there could also be the tray support ring. That ring has rollers which could be worn or might just have picked up some stray food residue which caused one or more of the rollers to not be totally round any longer.
Inspect the tray support rollers. Maybe they just need to be cleaned?
