sdcjjohnson
- REX4635EQ2
- Roper
- 6-10 years
Hi, I have a roper dryer that for some reason blew the thermal fuse. The i bypassed the thermal fuse and found the motor to run normal. When the timer is set to any setting besides off the heating element heats up and the only way to stop it is to turn the timer to the off position. This happens before the dryer is actually started. I have disconnected the power harness to the motor having only the thermostat, the switch, the timer and the heating coil stays on when the dryer is off but the timer is set to anything besides off.
Any ideas would be appreciated. Thanks
Model is REX4635EQ2 type #: 122-00
