thewoodenboatguy
- DMR57LFS
Hello, I've had this dishwasher since 2008 and haven't had any issues with it until recently. It's now ending it's wash cycle and showing the 5E code. Which is for discharge pump/ clogged drain hose. The drain hose isn't kinked , clogged etc. But, after removing the pump from it's housing I've found a small rubber flapper valve. It looks to be out of place but, not sure what port or ports it is supposed to be blocking. Does anyone have pics or any knowledge on where this is supposed to be. I tried Samsung and their tech support if laughable. Thanks in advance!
