- DMT300
I have a Samsumg DMT300 dishwasher...and a bazaar problem.
My first problem was the drain motor getting stuck on with no error codes. The dishwasher was completely drained, and opening the door did not stop the motor. I could get the motor to stop by slapping the front of the unit or restarting the wash cycle. I thought it could be...
1. A stuck rely.
2. Bad cable connection.
3. Bad Controller.
Lately it started throwing a low water level error, right before entering the drying cycle. Here is when things get bazaar. After the error is displayed, I turn the washer off. After a little while the washer turns on the drain motor. It stays on. It will go off if I slap the front of the unit or I start a new cycle.
After doing a little research I learned how to put the washer into "service mode". I ran all of the test without any failures multiple times.
Last night it threw the "low water level" error. I turn the washer off, and waited for it to turn the drain motor on. I then put the washer into service mode. It went into service mode with the drain motor running. The first mode test the input water valve. I turned the input water value on, and opened the door. The water valve shuts off and the front panel blinks indicating an open door error, but the drain motor continues to run.
The motor runs up until test cycle 6, which test the drain motor. When I advance to the drain motor test, the motor shuts off. I can then turn the motor on and off via the front panel buttons!!!
So I can rule out a struck relay...door sensor...water level sensor...cable connection. Which would indicate a bad controller, but the controller behaves correctly most of the time. What else could cause what I'm seeing?
1. A stuck rely.
3. Bad Controller.
