- DW80F800UWSAA
- Samsung
- 6-10 years
Having disassembled this dishwasher 4-6 times over 7 years, I am once again dealing with the dreaded 5E drain error.
May 22/2020: After a year of running without issue, 5E errors would not stop. Soap dispenser not opening. Appears to drain initial rinse water with no problem. But 5E stops cycle.
Took apart inside and cleaned gunk. After still coding in a Quick cycle, turned machine on right side, opened bottom pan, pulled out entire drain hose and flushed, replaced. Removed and cleaned the Assembly Case Sensor.
