Samsung Dishwasher DW80H9950US - No lights on touch pad
Andrew Buck
Kentucky
DW80H99
Samsung
Hey guys I am having trouble with my Dishwasher. I am getting no lights on the control panel at top. I have checked for loose connections and even unplugged and plugged everything back in. I have done some research but have came up with no results.
The white wire going into the control panel to the fuse? it is confusing me. Thanks for taking the time to read this.
Also background on the dishwasher a buddy gave it to me. He said it just stopped working one day and never came back on.
Hi Andrew,
Do you have a normal multimeter? As techs we don't use those pins. So I wouldn't rely heavily on that pin.
Take a volt reading at that fuse on your board, you should get 120 volts across it. If you do, then the problem is the control board not sending any volts to that control panel.
Power IN control board, but NO power OUT of the control board=a bad control board.
DD92-00041A Assy Pcb MAIN
