Samsung Dishwasher DW80K7050UG leaking from circulation motor
Jay84
Arkansas
DW80K7050UG
Samsung
the circulation pump motor seems to be leaking on the motor side. I took it out and took it apart and there was a small amount of rust on the corner circled and that is where I saw it actually leaking. I cleaned it out and seals looked fine but the impeller had play to it that seemed weird. Could that be allowing water to go through the shaft to the motor and leak? If so do I need the entire assembly or just the motor side? Still all works fine but just steadily leaks.
