FIXED Samsung Dishwasher DW80K7050US runs drain for 1 sec then stops, no error codes
N0SL3N
Toronto
DW80K7050US
Samsung
Yesterday, I found my dishwasher with about 30 minutes left on the cycle and lots of water in the tub, but would not restart. Every time I tried to start the cycle, I would hear the drain pump run for a second and water go into the drain, but then nothing. I repeated this process about 5 times until all the water in the tub was drained. I also cycled the power to reset with no improvement.
I had an issue with draining a few months ago, but also had an error code, which I fixed. I opened the dishwasher, the impeller looked fine and I found a small piece of plastic in the drain tube which I removed, however the issue persisted.
I thought the issue might be on the inlet valve, as no water was coming in after the drain, but I bench tested it and it worked fine. I then checked the latch switch to see if the door was showing as open, but it seemed to be working fine.
At this point, I have no idea what this could be and am inclined to believe it’s the board, but would like an easier fix.
N0SL3N
Toronto
Thanks Jake,
I haven’t run this test yet, but the drain does work, just for a short burst.
I did run the diagnostic from the manual you provided and am getting an AC6 error. I did auto and manual mode and it happened on every step, so not directly related to the drain.
I haven’t found much info on this, but believe it it a communication issue with the PBA.
Can you let me know if you have more info on this, otherwise I might just order a new one.
N0SL3N
Toronto
Update.
Replaced the board and everything works perfectly now.
Thanks for the help Jake
Excellent, glad to hear the new control board fixed it.
Here's the control board for your model in case others need it too:
