Samsung Dishwasher DW80R7060US 3c Code
rlaws
Weirsdale, FL
DW80R7060US
Roper
My dishwasher will throw the 3c code mid-cycle. I can drain the dishwasher by pushing the off button and holding for 3 seconds. If that is draining that way there shouldn't be a blockage? Could it be the pump? Would the pump still drain with pushing the button if that was the issue?
That would be correct.
No, because the drain pump would not run at all by pushing the off button and holding for 3 seconds, if the drain pump was bad.
I couldn't locate the service manual for your exact model, the closest I come is in this thread:
Here's the circulation pump for your model: Assy Motor BLDC;DW9900M,COMMON DD93-01013A
