FIXED Samsung Dryer DV365GTBGWR/A3 Panel not lighting up
Omar_VS
Miami Fl
DV365GTBGWR/A3
Samsung
I have a Samsung Steam Gas Dryer DV365GTBGWR/A3
For the past months it has been giving issues where it would turn off in the middle of a cycle and then you’d start it again and it would work.
Then sometimes you would hit the on button and it wouldn’t turn on. Until pushing a couple of times and then I’d turn on.
Now is definitely dead and not turning on. Breaker has power
Outlet gets power to the cord
But nothing in the control panel and no light inside the drum. Any ideas of what it could be?
Sounds like the control board is the culprit, unplug the dryer and see if you notice any burnt components on the control board.
DC92-00322V Assy Pcb MAIN
This video shows you how to access it:
Omar_VS
Miami Fl
Found it, do they sell just the switch so I can weld it back or I need to get the whole board?
Good find!
You'd need to get the whole control board as they don't sell just the switch to weld in.
Omar_VS
Miami Fl
FIXED
💪🏽 Problem fixed dryer is working now. Thanks for the help
