Samsung dryer DV403000EW goes off high limit
arbcon
pennsylvania
DV403000EW
Samsung
Interesting problem. Samsung dryer goes off high limit. changed thermistor and high limit but same problem. temperature actually measures 245 degrees at hole inside dryer so suspected thermistor was issue, changed and same result. dryer disconnected from vent and interior cleaned.
Wondering about control board but dryer appears fine. Belt taut and belt pulley spins. drum appears to spin normally. Wondering if motor overheating but no indication this is the case.
arbcon
pennsylvania
also think issue might be cycling thermostat. I know where it is on a whirlpool but where is it on a samsung?
DV403000EW is not pulling up as good, please recheck your model number. The model number tag is located inside the door, if your old like me and your eyes are as bad as mine ;) , take a photo of it with your phone.:)
