Samsung Dryer DV40J3000EW/A2 Control Panel clicks at relay on start, motor does not start
stevieskyline
North Carolina
DV40J3000EW/A2
Samsung
Recently I replaced the heating element, belt, and roller wheels. The dryer was working great for two weeks. Now, it the lights will turn on, but as soon as you hit start you hear a small click like a relay failing to click on.
I took the control panel off and tried to find the relay, and I believe it is this one I highlighted. Is there any way to replace any of these components, or is it just an order the whole assembly thing? The whole panel is epoxied down.
Is there anything you can recommend to me what may be causing this relay to just click?
Either the thermal fuse or door switch or belt switch or control board can be bad and cause the dryer not to run.
We will need to do process of elimination to find the bad part. If you assume its the control board and buy a new control board and that not fix it, then you just wasted over $100 for nothing, you see what I mean?
Lets ohm test your thermal fuse first. You will need a multimeter
Unplug the dryer from that wall outlet and ohm test your thermal fuse for continuity. When you click the part link to the thermal fuse below, you will see a video of HOW TO ohm test it.
Here's the thermal fuse for your model:
Thermal Fuse DC47-00016A
Here's the location of it on your model, that shows where its located:
stevieskyline
North Carolina
Thanks for the reply. The thermal fuse passed continuity, and the door switch is working (with the dryer on, pushing it in with the door open plays the sound indicating the door closed, and it allows me to press start and hear the click the post is about).
My main question is, how would I go about testing the belt switch? It seems to be a kind of off / on with the idler pulley up or down. I am confused on where to test this.
Ok,
Broken belt switch is near the bottom of the motor(Video included in part link):
Samsung 3405-001077 Broken Belt Switch
Make sure you disconnect power to the dryer before accessing it and ohm testing it. Let us know what you find.
stevieskyline
North Carolina
I tested the continuity on the broken belt switch and it passed continuity. Seems like the only thing left is the board itself, as everything else has passed continuity tests.
I made a short video showcasing the relay click I am talking about: Relay click
Does that sound like the relay failing?
Ok, yes basically all it can be now is the control board. Yes, I heard the relay click in your video, it does sound like its failing. But I don't have the tech. data sheet on this model, we can't be 100% sure without it.
What we just did is process of elimination, and in theory the new control board should fix it. If we are wrong then you have $150 paperweight that you can't return for a refund, but you could resell it on ebay and get some of you money back. You know what I'm saying?
By the way, just to be on the safe side unplug your dryer and check all your wiring connections because you started the thread off saying this below:
If you might of accidently left a wire connection loose, that could cause the dryer to not run as well.
Assy Pcb Main DC92-01025D
