koposcabana
- DV42H5200EW/A3
- Samsung
- 6-10 years
Problem: Samsung dryer will run 10-30 minutes then throws error "HE". Heating element is activated and dryer does get hot.
Tested:
Any ideas or things to try?
Tested:
- Relay: Turns on when dryer is started and 120v supplied.
- Heating Element: [Replaced - DC47-00019A] Element has clear break in continuity.
- Thermistor: [Replaced - DC32-00007A] Was reading a little low 9.5k ohm vs expected 10-10.5k ohm at 70F.
- Thermostat: [Replaced - DC47-00018A] Was reading 0.02ohm at room temperature, but I thought it might be failing at high end to shut off.
- Thermal Fuse (Heating Element): Checked continuity 0.1ohm
