Samsung dryer DV50F9A6VW/A2 Runs about 2 min then shut off, Timed Dry works great
swebeaux
louisiana
DV50F9A6VW
Samsung
Works fine on timed dry
On auto runs 2-3 min then timer jumps to 1 min
Sensor bars have been cleaned and has continuity from the bars to the main board
Main board has been replaced but the problem persists help p!ease.
Please recheck the model number, this is the closest I get:
Model #DV50F9A6GVW/A2-0001
Model #DV50F9A6EVW/A2-0000
Model #DV50F9A6EVW/A2-0001
We are getting closer.:)
Is there no more numbers after the A2?
Then it sounds like the moisture sensor bars are faulty.
Here's the moisture sensor bars(Order 2):
Moisture Sensor DC61-02627A
swebeaux
louisiana
I disconnected the sensor bars at the plug and installed a jumper wire creating a direct short between the 2 sensor bars and the problem is still there
In my thinking that would have eliminated the sensor bars being the cause, I did this prior to replacing the main board
Do you still believe the sensor bars are the culprit
That's odd, no then your sensor bars should be good. I really don't know what could be causing it. I very little experience on Samsung products.
Wild is our Samsung expert here, he may be able to assist you.
You can PM Wild, click here wildimaginations then you will see a menu on the left side that says Send Private Message, then refer him to your thread here.
swebeaux: Did you ever find what was causing this?
Another member is having the same exact problem.
