Samsung Dryer DVE60M9900V/A3 - Dead Brick
Steve727
Colorado
DVE60M9900V/A3
Samsung
I have a relatively new (2-3 year old) Samsung "flex dry" dryer which has unfortunately stopped working. Completely stopped - no lights, no beeps, no heats, no turns. Since it was still under warranty I called for repair and they came out and looked at it. The young man left saying it was a bad PCB and that they couldn't find the replacement part because it was "too new." He reported his finding back to the company and they refunded my money. They left me the dryer. So, with the help of my appliance repair friend Mike, I was hoping to fix this thing. Mike asked if I had a wiring diagram for the machine, which has led me here. Does anyone know where I might a wiring diagram?
Thank you in advance
Steve
Your tech sheet and wiring diagram should be in an envelope taped to the inside of a panel or inside the console. That is if the tech didn't take it with him.
Check if you're getting supply voltage to the main control board. Sometimes the connectors are labeled on the board. Look for AC or L1, L2 and Neutral
Steve727
Colorado
We took the dryer apart last night and chased continuity from the plug all the way to the pbc thru the thermal cut offs, switches, and the motor. Anyway, we could have saved ourselves a lot of time and effort, because in the end we found out that we have power (120 volts) getting to the board. Is there a way to test the pcb?
Steve727
Colorado
Ok, that's what we thought too but I wanted to ask someone who knows more than us.
The link for the item above appears to be for the pcb display not the actual board.
It's for both boards. It looks like the control board doesn't come as a separate part
Steve727
Colorado
Package arrived. The link above is for the display only. The PCB is not included with the order.
