FIXED Samsung duoflex electric range NE58F9170WS/AA front left burner stopped working
hmb1030
Oregon
NE58F9170WS/AA
Samsung
I have a Samsung duoflex electric range NE58F9170WS/AA that is 7 yrs old. A month ago, the front left burner stopped working. This burner has a bridging element. The bridging element and the back burner continue to work, just the front burner does not work. Anyhow, we replaced the burner with an off-brand burner (Samsung discontinued the needed burner). A small area to the coil of the old element looked burnt so we thought replacing the burner would fix the problem. However, replacing the element didn't fix the problem, so we replaced the switch regulator but that too did not get the burner to work. What else could be wrong and how do we troubleshoot it?
Everything else seems to work fine. I would hate to put out another 2500 for a new range just for a nonfunctioning burner.
Thank you for your help.
Turn the LF switch to high and check for 220 VAC on the switch, L1 to L2 and H1 to H2
hmb1030
Oregon
Update: Evidently, we wired the "off-brand" element incorrectly as it was slightly different than the Samsung version. The new element is now working as it should after correcting the wiring. FIXED.
