FIXED Samsung DV40J3000EW/A2 Dryer won't start
Noblet84
Seneca SC
DV40J3000EW/A2
Samsung
I have tried every setting, and the dryer won't start. I only get a click sound when the button is pressed. I was told the dryer just stopped working one day.
Either the thermal fuse or door switch or belt switch can be bad and cause the dryer not to run.
Lets ohm test your thermal fuse first. You will need a multimeter
Unplug the dryer from that wall outlet and ohm test your thermal fuse for continuity. When you click the part link to the thermal fuse below, you will see a video of HOW TO ohm test it.
Here's the thermal fuse for your model:
Thermal Fuse DC47-00016A
Here's the location of it on your model, that shows where its located:
Glad to help, yes keep us posted.:)
Noblet84
Seneca SC
The belt was the problem. It has a cut off switch that activates. Thanks you.
Excellent, glad to hear it was just a broken belt, making the belt switch not activate.(y)
Here's the belt for your model, in case others need it too, (Video Included):
Drive Belt 6602-001655
