Samsung DV42H5000EW/AC - Drum keeps spinning when power is off.
Saskatchewan
DV42H5000EW/AC
Samsung
So I had this problem about 3 months ago, where the drum kept rotating with no heat even when the dryer was turned off. My initial research indicated it was likely due to a stuck relay in the PCB control board assembly. I ordered a new Samsung part and it worked properly for the next 3 months. Now just a mere 5 days after the 90 day warranty for the PCB board expired, I am having the same problem. Does anyone know if these boards are prone to failure? or if there is a more reliable source available? Both Samsung and the retailer I purchased the part from are being difficult and are not honoring the warranty.
Yes, these boards are prone to failure.
Both the links below have a 365 warranty on ALL parts!
RepairClinic Ships to Canada:
