Samsung DV45H7000EW timer runs for 1 minute then timer drops and cools down
Annah
California
DV45H7000EW
Samsung
Hi everyone, i'm new here and need help. My Samsung washer 18 months old (i'll never purchase another samsung product again!) just broke 2 days ago and we had to buy a new one. Today my Samsung dryer also 18 months old has done the same. I'm attempting to fix it myself because I cannot afford a new one.
Dryer runs for 1-2 minutes then the timer suddenly drops to 1 minute from 57 and goes into cooling mode and shuts off. I tried unhooking the vent and running it without it but that didn't help anything.
Any help/direction is appreciated.
Annah
California
Thank you Jake, I did a lot of reading and as a result tried cleaning the moisture censor with a fine sand paper and rubbing alcohol. IT EXTENDED THE DRY TIME And shut off around 30 minutes of a 59 cycle, so then I tried a timed cycle not the auto it worked normally. Is it safe to say it's the moisture bar that needs replacing? That way I can go ahead and order it. Thanks again!
First try cleaning the moisture sensor bar with rubbing alcohol, many members here have had good success doing that.
