Samsung DV45H7000GW/A2 Heats Intermittently
jacobhorton27
California
DV45H7000GW/A2
Samsung
I have a Samsung DV45H7000GW/A2 gas dryer that is giving me the round about. The dryer seemingly stopped heating. I checked the entire exhaust system from tip to tail, no clogs or debris.
After disassembly I found the pattern, dryer comes on, igniter glows, burner lights and burns for about 10 seconds, igniter turns off, burner turns off. About a minute later the process repeats.
I have since replaced the thermal fuse, the thermistor, the high limit thermostat, igniter, and the gas solenoid coils. The problem still persists.
I am at a total loss, and I am running out of clean clothes. Does anybody have a any ideas of what else I could try? Any help would be appreciated. Thanks!
Pull the dryer out from the wall, then remove the exhaust hose from the back of the dryer, then start the dryer with NO CLOTHES in it and see if the flame stays on much longer and heats properly.
