FIXED Samsung DW80J7550UG error (blink 3 time & chime 3 times)
Relentless85
Oklahoma
DW80J755
Samsung
Samsung DW80J7550UG dishwasher. After pressing the start button the units chimes 3 times and blinks the light under the handle 3 times but does not display a code on the screen.
After about 5 time of the blinking and chiming, the unit will finally start filling with water.
I can’t find any info on what it is doing since it won’t give me a code on the screen.
Any ideas on what is causing the blink and chime with no error code?
Relentless85
Oklahoma
Well i must be doing something wrong. I read page 44 of the manual.
I pulled the software version by holding the zone booster L and R and Power button at the same time. It is showing version 7136.
Now if I do the check code recall process by powering the unit on the. Holding the normal and lower key, I don’t get any codes or beeps just a snowflake/star burst symbol on the display.
I can’t seem to get it to give me a code. But there is something definitely wrong with this thing. Any ideas on how I can get it to give me a code?
Upon power on and cycle start, the drain pump starts to run then I hear a grinding noise as the water wall arm moves toward the front and rear of the unit. Then followed by the 3 chimes and light flash.
If I power it on in test mode then hold the normal and lower buttons I get a bC2 code, but from what I read that is just telling me that a button has been held too long?
That's odd, I really don't know then.
Hopefully another tech. that's seen this problem before can shed some light on it for us.
Other than that its best to contact Samsung to come out to see what's going on.
Yes, it seems you are.
Ok good.
(click to enlarge)
Gert
Manitoba Canada
Hello. I am having the same (3 chime, 3 blink) issue on our DW80J9945US.
s/w v 7142
What would my next steps be in this case?
Thank you
Read my Post #2 about pulling the error code.
I don't see a error code dC in your service manual. It's best to have Samsung come out to see what's going on. I don't work on Samsung products, I'm just going by the service manual.
Gert
Manitoba Canada
Unfortunately the cost to have a tech come see this machine is higher than replacing the unit due to mileage. I am attempting to exhaust all options prior to going down that road.
I did not see my software version in the manual posted above either. could there be a more recent manual available elsewhere? In your experience would contacting Samsung directly be of benefit?
Thanks for your help with this.
Relentless85
Oklahoma
Ok, I finally had some more time to mess with mine. I connected water and power to the dishwasher and pulled a 7C code.
Appears 7C has to do with the motor that moves the water wall on the bottom inside of the dishwasher. From what I read there is a motor that drives the water wall and there is some sort of sensor that detects where the water wall arm position is.
I did take a video of the arm trying to move. The motor make a loud sound like it is trying to move the water wall arm but the arm only moves a little bit sometimes and other times it moves like it is supposed to.
Looking for part number for the waterwall drive motor and the sensor too. Any ideas on what part numbers they are?
This is the waterwall drive motor:
Its out-of-stock at RepairClinic, but in-stock here:
This is your sensor:
mschum1
Ohio
I had this same problem (knocking sound, 3 beeps, 3 light flashes, about 5 times before wash cycle started) on my Samsung DW80J7550UG. It started happening when the unit was 2-3 years old (not good IMO...). I recall that mine didn't have an error code (or it was one that wasn't listed, not sure). I saw a video where a guy had fixed his by replacing the magnet that rides on the moving part of the waterwall with a more powerful NIB magnet. I tried the same but it didn't help, so I kept looking.
This blog had the most relevant information but didn't have a conclusive answer. I think I have that now - I replaced just the vane sensor (Sensor-VANE;DW80H9000,5V", Part Number: DD32-00011A) yesterday, this fixed the problem in my case - no more beeps, no light flashes, and washing seems to start normally. I did hear a couple of knocks, which I think are the moving part of the waterwall reaching/hitting the back stop, but it was noticeably reduced.
The sensor is little difficult to get to. You have to pull the unit, remove the back panel (2 screws) to access the connector, set the unit on it's back, and remove the bottom cover (clips only). I replaced the sensor without removing the 3 black hoses in the way (on the bottom) but ended up breaking the clip that holds the sensor in place. Removing the hoses is probably the better way... It took about an hour or two with only basic instructions and a general idea about where the sensor was located.
Mike
Excellent Mike, Glad to hear the new vane sensor fixed yours. (y)
Thanks for letting others know!
Bellawaves
Florida
My dishwasher is also giving a 7C error code. How likely is it that a new vane sensor will fix mine too? I don't want to buy and try multiple parts, if I can avoid it. :)
I select a cycle as usual, press Start, close the door. It makes a sort of grinding noise, I hear the drain running, grinding noise continues awhile, sometimes sounds as if the water is about to start (maybe??)... then all stops, light flashes, bings 3 times. The lights and bings continue periodically until I open it, then I cancel the cycle. I did notice after one of my multiple tries to start it, that the water wall arm was at the front when I opened the door, and after another try it had returned to the back.
According to the service manual, 1 possible cause is when the vane is blocked. Where would I check for "vane is blocked"? The water wall arm in the bottom isn't blocked.
Really hoping the cheaper sensor vane would fix mine too!
Amanda
seibtb
Alberta
Mike
I had the exact same problem as Mike and replace the sensor vane (even broke part of the clip). Turned it back on and its doing the same thing as before. :rolleyes:
So now I have no clue what the issue is. The error code was 4C but everything seems to check out that I can think of.
CaraS
Carmel, Indiana
Jake-
I have the same model (DW80J755) and I have read and re-read pulling the code. The software code that it gives me is 713E. I'm confused because the page 44 shows a different model. And the software code that my Samsung is showing isn't even there. Any thoughts?
The only "codes" it is giving are "bc2" and "dc"
Thank you in advance.
Carol
