Samsung Electric Oven Model FER300SX Not Heating To Temperature
Pewaukee, WI
FER300SX
Samsung
Hello. My Samsung electric oven has stopped heating to set temperature although it will heat up somewhat. The broiler works just fine. Coincidentally a section of the LED clock display is out. I know this oven is about 10 years old. Wondering if this could be an easy inexpensive DIY fix or not worth fixing?
Yes, you will need to replace the clock oven control board and possibly the bake element, but disconnect power to your range and remove it first to see if its broken.
Here's the clock oven control board for your model:
Samsung DE92-03045B Assy Pcb Main
Here's the bottom BAKE element for your model:
Both parts together are going to run over $300 to order, there are videos on how to replace both parts.
