Vanilla007
- FR31FMEDBSR
- Samsung
- 6-10 years
Hello,
The Freezer section is fine. The Fridge section is set at 37, but it is warm 58F
We replaced (without checking if the old ones worked. Don’t know how to check them)
1.temperature sensor inside the back cover (white with long yellow cord)
2. Temperature sensor on the evaporator coil, top right (white with short yellow cord)
3. Black defrost thermostat (on the top left, plugged into evaporator coil)
4. Installed 2nd heater from Ben’s
After installing Ben’s second heater 10 days ago, the temperature was high 49F, displayed showed 80F. That’s why we replaced 2 sensors and thermostat, now temperature shows 58F on display, which is correct.
(Before installing Ben’s heater, we were defrosting manually often. And temperature was kind of random after defrost, freezing fresh food sometimes)
I wonder, what else can we do? What else to check? (And how to check)
Thank you!
Thank you!
