SAMSUNG fridge RS2556SH dispenser water and ice maker will not fill
Danhcdo
Falls church
RS2556SH
Samsung
I HAVE THE SAMSUNG RS2556SH
Water dispenser and water line for ice maker are not dispensing water
I tried new inlet valve, even test it for continuiity
I replaced with new filter, water flows strong and good when turning on water valve.
There is power going into inlet valve
I reset the icemakers but water will not disperse into the Icetray.
When pressing the water dispenser, the water from the water valve did not flow into the solenoid, it looks empty and dry inside.
What should I check next?
Sounds like a problem in the water filter housing. Take the water filter out and use your by-pass plug and see if water starts to flow out the water dispenser.
Here's the water filter housing for your model:
