- NX58H5600SS/AA
- Samsung
- 1-5 years
Hello everyone,
I hope you are having a great day!. Well I thought I could fix our 3 year old, (new I thought) gas range.
So far everything I have tried has failed, so I have broken down and come to you here for help
My Samsung unit has a model number: NX58H5600SS/AA Feb 2019 looks like Manufacture date.
Our previous range, a whirpool has lasted 12 years with no issues. Its still going in our mother in law quarter
Are Samsungs lemons in comparison?
haha sure seems like it, well maybe we can remedy this issue. I'm willing to try one more (3rd) time.
So my First shot was replacing the PCB. DG92-01107A -the same issue came up where the oven beeps, the display says heating oven, some high temp like 355, goes off, after some time -te- will display. sometimes it would try to start heating but the temp never went above the starting point. My wife said it actually started heating one time when I was not home.
I read another thread where the switch membrane solved the problem on the same Samsung oven/ or maybe that was an -se- error code
I tried this p/n DG34-00027B. (switch membrane) unfortunately i forgot to test membrane before installing the 3M adhesive and is now fully installed, ribbon cable is cinched, all plugs tight, etc. However, our issue remains, When I plugged the oven in to test, the clock beeps but the buttons do not work to change the time. about 30 secs later -te- and beeping occur so we just unplug it. bummer
Is there anything else I can do.? I should be getting a refund on the PCB that was returned, but the switch membrane is a lost cause? Maybe I can remove with a heat gun at try to return, but I am not sure if you recommend that.
Any help would be fantastic! Have a great day
