Samsung Microwave No Power
hametown
Akron, OH
SMH8185B
Samsung
Less than 1 year
The unit is completely dead. It was running when the power quit. No noise. Ther outlet is powered and the unit was unplugged then replugged. I suspect a thermal fuse but do not know how to access it. Thanks
You should be able to access the fuse behind the control panel. There's probably only one screw on top but you might have to remove the grill first. If the fuse is blown, you'll need to use a meter and check the door switches for continuity. Always disconnect at least one wire from the switch you're testing. Always unplug the microwave and discharge the high voltage capacitor before doing any service on electrical components.
