Samsung Microwave Power issue
Blue girl
London ontario
Smh9207st
Samsung
Started with problems with the fan running continuously after microwave cycle completed. Pointed me to the switches. Thought I'd be smart and clean the small cavity where the door hooks lead to the switch. Did not unplug it(stupid I know) and moisture got into the switch and I heard a loud pop and all went dark. Checked the 2 fuses, 1 was bad 1 was ok. Changed the bad one out and checked all 3 switches for continuity and inside each switch to see if anything was broken. All 3 look brand new & making good contact. Now with new fuse I only get the exhaust fan and the microwave cavity light but no panel action at all. Also the fan is slower and the light is dimmer. I felt like the pop noise came from the back left of the machine. I don't think I mixed up the switches, but anything is possible. Any help greatly appreciated.
Find the diagram inside? If yes, can you post a copy here?
Checked for power coming into the board?
Hope not, they are position sensitive.
bluegirl64
London Canada
Took the appliance off the wall today but no diagrams found inside the cavity. I have found a repair manual online. I can certainly email it to you if that would help.
I see HV tranformer fuse, 20 amp fuse, bottom thermostat, 1 cavity thermostat and 1 magnetron thermostat that all should have continuity.
Looks like if the cavity or magnetron thermostat are open the light and exhaust fan could still work. Failing those you will need to check for power into the low voltage transformer.
