- NE58K985OWS
- Samsung
- 6-10 years
Hello,
Samsung Model NE58K985OWS with dead control panel. Stovetop burners work. Based on research and a forum posts, suspect the display pcb but checking for any specific checks, such as voltage checks on the board itself to help isolate the issue and make sure the issue isnt' another component or main pcb. Suppose since the strove top burners work, the main pcb is ok. Without a schematic, I'm not sure. Although a tech sheet/wire diagram is attached to the back panel, there doesn't appear to be any voltages that correlate to the connectors. The connectors on the board aren't labeled but the number of pins help id the connectors. I found a flow chart that mentions connector CN401 but it may be for a different model since that connector number doesn't appear to be listed on the tech sheet.
Thanks for the support.
Ken
Ken
