Samsung NE59J7850WG oven will not maintain temp when its on lower oven setting
Robb5141
NE59J7850WG
Samsung
Oven. The oven will not maintain temp when its on lower oven setting. I tested Tstats upper and lower they ohm in spec range, also ohm all elements, convection fan motors etc. When I run oven and check voltage at elements upper and convection elements they show voltage as their working. I kept volt meter on lower element for like 10 minutes it never showed voltage (240v). I have voltage to ground 120v each side of the lower element. I believe pcb main control board possibly the relay that controls that element is not working properly. Am I on the right track?
Robb5141
Ok so that board replaces what is currently on my stove cause my main board is DE41-00461A?
Yes, that's correct.
