- NE58K9500SG/AA
- Samsung
- 1-5 years
Samsung NE58K9500SG/AA Range - Oven control panel would not light. Discovered relay board was faulty (appears that heating element relay short circuited). Replaced with new relay board. Everything appears to work properly now except the range control panel cooling fan (DE31-0070A) will not turn off. Range oven temperature sensor provides correct ohms at room temperature. Removing connector from oven temperature sensor does not change behavior. Temperature limit switch tests OK.
