Samsung Range NE58K9850WG/AC control panel went blank
John@
NE58K9850WG
Samsung
Our Samsung oven first time went off while using broil function for upper part. It came work fine after circuit breaker reconnected.
Since then, The display board went off after baking while oven was cooling. We need redo circuit breaker before using the oven. Now, the display board went blank even without using it.
Please help me.
Added complete model number
Your missing some digits at the end of your model number, take a photo of your model number tag and upload it here.
John@
Yes, Your are right. Thank you, Jake.
John
John@
Is there any other parts number that comparable with the one you listed?
Thank you
Contact your local appliance parts store in your area, they may have it in Canada.
Not that I'm aware of, but you can ask them that as well.
Anytime John!
John@
Hi Jake,
I did some observations, There is a 9/10 pin connector that communicate between Main PCB and sub PCB. It seems that protector of the SMPS kicked in cut the power .
which one you think it is on fault? Main PCB or Sub PCB .
Thank you
I don't know John without looking at the tech. data sheet, which I don't have.
Your welcome John.
