Samsung Range NE59J3420SB - HOT SURFACE light always on
fncruz
NJ
NE59J3420SB
Samsung
My Samsung Range NE59J3420SB has the HOT SURFACE light always on. As a result I cannot use the self clean function as it thinks the range is hot which is a safety function.
Is there a part I can buy to fix this hot surface issue?
Thanks.
FC
Does your model have a HOT SURFACE INDICTOR LIGHT for each surface burner? Or just ONE HOT SURFACE INDICTOR LIGHT for ALL the burners?
If for each burner, which one is staying on all the time?
Ok I could not locate the wiring diagram for this model, but look inside the back of the control console and see if its there.
What you'll need to do is disconnect power to the range, then take a photo of your wiring at the burner switch, then remove THE TWO WIRES to each burner at each burner switch(ONE AT A TIME) and let the wires hang in the air, making sure the metal terminal connectors do not touch anything, then power the range back up and see if the HOT SURFACE light goes out.
Do that for each burner switch till the HOT SURFACE light goes out, then you will find the bad burner causing this issue.
fncruz
NJ
I can't find a wiring diagram anywhere.
Any idea what each burner switch looks like? I would be happy to try to find which one as long as I know what it looks like.
fncruz
NJ
I got Samsung to send me the wiring diagram. I will test it soon and get back to you.
Yes, that is confusing, I will need to ask Rick.
That's the most stripped down, bare bones wiring diagram I've ever seen. LOL Stand-by
My thoughts exactly Rick. LOL
I went over that diagram and tried to follow the markings but I can't make heads or tails out of it. I can't tell where the wires on the hot surface indicator go. BL8 and BL9 are on the connectors A-1 and B-1. That doesn't tell me anything unless I know where the wires in the connector go. I can't find the other two wires. My guess is each connector is for two elements (right side-left side). Since there's only two wires on the hot surface indicator, the other two being neutral side, unplug the connectors one at a time and see if the light goes off. Maybe that way we can at least narrow it down to one side or the other.
Forgot to add: The hot surface indicator gets it voltage from the element limiter.
Thanks Rick!
I checked the wiring diagram for a Samsung range with a hot surface light and four elements. It had one single element two dual elements and a triple element. The hot indicator light had one wire common to all four elements from the temp limiter on each element and a neutral wire.
