- NE59K3310SS
- Samsung
- 1-5 years
Hello,
We have a NE59K3310SS stove we inheritated with our recent house purchase.
We’ve noticed the following two issues:
1. Oven doesn’t heat up to desired temperature: 25 degrees off. Fix: add 25 degrees to desired temperature. Today we recalibrated the stove to avoid this step.
2. Oven preheats to desired temperature - sometimes all the way to 450 (using analog temperature thermostat to confirm) but drops heats shortly after and does not recover. Anywhere from 50-25 degrees.
Things we’ve tried:
-tested oven thermostat. Ohm reading is within acceptable range.
-removed and tested bake element. No issue with continuity. Visually looks ok, but photo attached to confirm. We assume the erosion is more the coating vs an actual issue but happy to be wrong.
No connectors were loose, and nothing looked burnt out other than the oven light.
Any ideas? We’ve read about replacing the control board, but wanted to get an opinion before buying it as it’s $200 and feels pricy if it’s not the issue (as it wasn’t with another thread on here I searched first)
Things we’ve tried:
