lenhardgil@gmai
- NX58H5600SS
- Samsung
- 1-5 years
Appreciate any help with this issue. When turning on oven bake, ignitor glows, after 20 seconds gas comes on, ignites, burns fine, but then gas shuts of after 15-20 seconds. Ignitor stays glowing, after 15-20 seconds gas comes back on. It keeps repeating this, with the time between turn on /shut off growing less, until it stays on steady, and reaches bake temp.
Other info:
1) checked ignitor resistance=188 ohms, within spec of 4-400 ohms.
2) Top oven broiler works fine, steady, no intermittent gas flow problems.
3) same behavior happens on convection bake. As side note, wife reports convection bake fan does not appear to work as before, but I am unsure of normal operation (should fan be continuously on through heat up and bake cycle?)
4) checked for error codes, it says HO E AA. I do not see that in service manual.
My guess is a bad gas safety valve, or control board, but could use some trouble shooting guidance to isolate problem.
Thanks.
Other info:
Thanks.
