Samsung Range NX58H9500W - oven stays in preheat
katmoons
Massachusetts
NX58H9500
Samsung
Hope i can get clarity on the part number I need. When the oven is turned on for bake, the display says preheat. When my son turned it on and walked away for several minutes, by the time he got back in the kitchen the oven did not heat and the kitchen was full of gas. After looking at all the possibilities I think it is the igniter (please let me know if I am wrong:) When looking at parts I found two parts called "Range Oven Burner Igniter" and "Range Bake Igniter". Which is the proper one for my Model?
Thanks for any help
Let's check it first. Remove the oven floor to access the igniter. Set the oven to Bake and see if it glows red. If it doesn't turn on check for 120 VAC at the connector.
If it does turn on and glow red you need to check the igniter amps. The igniter needs to draw 3.2 to3.6 amps to open the safety valve:
