madnad
- RB2044SL
- Samsung
- More than 10 years
I apologize at outset if this problem has been addressed. To me, it seems quite perplexing and I am at a loss of what terms to search for inorder to get to my solution.
Samsung fridge/freezer model number RB2044SL. Old fridge, sitting in the garage.
Problem: The compressor does not kick on after it has stopped (on reaching set temperature). Requires restart to kick in again, and cycle repeats.
My observations:
1. The compressor and its fan (at the back) start up normally and run for about 2 to 3 hours (or however long it takes to attain the set temperature). So compressor and start relay appear to be good.
2. The controls seem to be working normally - I can change the temperature settings, turn on PowerFreeze or PowerCool.
3. There is water/condensate in the bottom tray - so defrost cycle is happening and it is getting cleared. I also took apart the conduit and cleaned it for good measure.
4. Upon first start (or power cycle) - the temperature readout on display concurs with my reading using handheld temp sensor. I also have a WiFi temp sensor sitting inside the refrigerator which sends me readings on the phone periodically. I can verify that the fridge is getting cold and reaches set temperature. Then it starts to warm up on my phone readings. But the temperature readout on the display shows my set temperature (for eg. 36 for fridge and -2 for freezer) not the real temperature inside [this is normal operation from what I read]. So then I power cycle it and the onboard temperature displays the warmer temperature as it is. And the compressor kicks in, starts to cool. If I don't power cycle then the refrigerator starts to warm up and it can keep warming and go up to 60 deg fridge and 20 deg freezer if I don't intervene .
What I have done so far:
I have replaced the temperature sensor in the past, but don't think that is the problem as it reads correctly after restart.
I have replaced the thermal fuse more than once because it was blown - and I would like to know what I can do to prevent this. I have checked it for continuity and it is not blown.
I have cleaned out the drain in the freezer and fridge. There doesn't seem to be any major ice buildup.
When the refrigerator is working (after power cycling), I can confirm that there is cold air moving in both the chambers.
I haven't tried forced defrost lately, or run diagnostic code as I don't know how to.
I will be happy to provide additional information, try out some suggestions. TIA.
My observations:
