Samsung Refrigerator RF261BEAESR - Water collecting and freezing at bottom of Refrigerator
Burgian
Michigan
RF261BEAESR
Samsung
My Samsung fridge had a drawer at the bottom of the cooling area. Below that is the large drawer freezer. Water seems to collect and freeze below this drawer in the fridge. How can I stop this from happening. Thanks.
Its most likely the refrigerator evaporator drain hole is clogged up, thus not letting the defrost drain water go down the drain hole.
I use a evaporator cooler spider snake to run down that defrost drain hole: https://www.azpartsmaster.com/products/24-evaporative-cooler-flexible-spider-snake_913
They are used basically in Arizona to clean out the water pump tubes that run to the cooler pads.
I don't know if they would sell them in your area, but if you go to your local hardware store, they should have something similar to run down your drain to clean it completely out.
Then run hot water and a little bleach down the defrost drain hole.
That should fix it for many years to come.
Watch this video below, it shows you how to remove the refrigerator evaporator cover assembly, at about the 4:23 mark you can see the evaporator coil, look below that coil and you see the metal drain trough with the drain hole in the middle.
Thanks Paul, I fixed the page link to that cooler spider snake.
Sounds good Paul.:)
