Samsung Refrigerator RFG297HDRS/XAA Noisy
Manju
Kansas
RFG297HDRS
Samsung
Hello we have a Samsung RFG297HDRS/XAA Twin Cooling refrigerator (8 yr old) that makes a humming noise whenever the fridge door is closed. The noise disappears when the door is opened. We have noticed some ice buildup on the back wall inside the fridge, where the vent holes are. Any ideas how to fix this? We seem to keep having to unplug the fridge, empty the contents, and leave it to thaw out the ice, every 6 months to 1 year. Is this normal and what needs to be done often, or you think is a part not working properly?
Apart from the humming noise, the fridge and freezer seem to be working OK for now.
Any help is much appreciated!
Manju
The noise is probably from the RC evaporator fan. Can you pinpoint where the noise is coming from? Remove the cooling tower and see if the evaporator is frosted over. Check the defrost heater for continuity.
Manju
Kansas
Thank you for the response! I have not removed the cooling tower yet, but I would say the noise is coming from the fridge side, around the second set of the vent holes in your picture. That is where we have noticed some ice buildup on the back wall inside the fridge, right where those holes are.
Where exactly is the defrost heater located?
The fan and the cover are all one piece. If the fan quit working you'll get frost. This is what the back looks like:
The defrost heater looks like the black calrod style element in your oven. It runs down one side of the evaporator, across the bottom and up the other side.
Manju
Kansas
Ok I understand. So what do you think is making the humming noise? I thought it was the fan blades hitting the ice as they rotate?
That's the one thing that's hard to do with online appliance repair, diagnose noises....LOL I'm sure it's related to the fan motor. That's the only electrical component with moving parts in the FF section. You'll just need to take it apart and see what's going on behind that cover.
Manju
Kansas
I agree. I do have a continuity tester. What other components would you test for, other than the defrost heater element?
We saw a lot of ice buildup through those vent holes on the cover, so now we are letting it all thaw out and see if that makes a difference, at least temporarily. Do you hear from folks that certain fridge brands are better than others? We are thinking of fixing this one, and buying a new one!
The main control board uses the information from the sensors to know when to start a defrost cycle.
The consensus among service techs is Samsung and LG are the two worst machines ever made. Everything else is better...lol
Manju
Kansas
Can you tell me the part number for the defrost heater for my fridge? All I have managed to find so far is the entire evaporator assembly which is:
Part DA96-00762L.
Thank you
That's the only one I found also. Probably the reason no one wants to work on Samsung machines. Check it for continuity. Lets see if it's bad first before trying to find one..
