Bob_Dittmar
- RFG298AARS/XAA
- Samsung
- More than 10 years
Hello
Apologies if this has been covered on this forum already, but I could not find my model number and this topic although I found this topic for other models. I reviewed those threads but still have some questions.
Symptoms:
I replaced the freezer compartment temp sensor DA32-10105B as that was quick and easy to order, and this was before I learned how to read the current temp from the front panel… No change in behavior after changing this.
I’ve now been using Samsung publication tsRFG298AA rev 03/30/2011 for troubleshooting and mainboard diagrams.
Run the self-diagnostic, no LED error codes show on completion.
With freezer door switch closed, I can feel the air from evaporator fans moving through the back panel duct work. So Fans are working and controllable by the controller.
Pull the back panel of freezer compartment to expose the evap coil, leave the fan assembly plugged in so no sensor errors and close the freezer door switch.
Compressor is running and the fan for condenser coils is running.
I put the compressor into Force Mode and checked all 3 speeds – by hearing increased rate, not measuring voltages.
Have monitored temp sensor voltages at CN30 to the mainboard ground and show the closest conversion to temp using the table in the troubleshooting guide.
Reseated connector on the stepper valve.
Some other things I’ve noticed:
My suspicions are:
Suggestions would be appreciated.
Bob
Symptoms:
- Refridge section can reach 34F no problem.
- Freezer section doesn’t have any cooling – even when put the front panel in Power Freeze mode.
- Forced an error by disconnecting some sensors and diagnostics detected it with LED code, so diagnostic routine runs.
- Evap coil never cools or frosts, only slightly cool to the touch but this might be conduction from the refridge maybe???
- Cn30-3 F Sensor: 2.016v (62.6F)
- CN30-4 F defrost sensor: 2.158v (57.2F)
- CN30-6 R sensor: 2.781v (35.6F)
- CN30-8 R defrost sensor: 3.630v (3.2F)
- Once after probing on the mainboard connectors and reseating connectors by the evap coil assy, the evap coil did start to chill and form some frost just near the entry of it. But then after unplugging the unit to button some things up, it never chilled the evap coil anymore. I cannot attribute what I might have done to allow the Freon to get to the evap core.
- When cycling power, sometimes the inverter board doesn’t start up properly.
- Several times it gives no LED status.
- Several times I get single pulses for startup failure.
- Several times I get dual pulse for SPM fault.
My suspicions are:
- Mainboard is going into defrost mode for the freezer but is never coming out of it.
- The defrost sensor seems good, so not sure what else can cause this.
- Stepper valve is not working to engage the Freon to the freezer evap.
- Not sure how to test/verify this.
- If nothing else makes sense, then maybe bad main board?
Bob
