Samsung Washer WF448AAP/XAC not draining
Dontaskme422
WF448AAP/XAC
Samsung
Hello,
Was getting a drain pump error at the end of a normal cycle. Then the cycle would not start at all. I ordered a replacement drain pump and installed it today. Again, it filled up and started to wash, but it stops at the point where it should drain, quick wash being 26mins, and just stays there. No error message. I don't hear any clicking or buzzing when the pump should start up. I checked the hoses and they were fairly clean.
I took a look at the motherboard and everything is glued/sealed to the board, and I saw that the board is no longer replaceable? Can I jumper/hot wire something in the motherboard to get it to drain? Thanks.
I always check for 120 volts at the drain pump electrical connector when it should be draining with my multimeter, if no 120 volts then yes, the main control board is the issue. Yes, unfortunately its No Longer Available.
Samsung DC92-00133A Assy Pcb Main
No, not that I'm aware of.
The drain pump connector is the electrical connector that snaps into your drain pump to power it from the control board.
