slok
- WF520ABW
- Samsung
- More than 10 years
Ran a load in my washer and it stoped with the message that the load was unbalanced. I took some stuff out and started it only to walk away and come back later and it was stuck at the same time countdown. I tried running it again and finally noticed that it would not spin counter clockwise and was stuck on the current cycle. From some research I assumed it was something with the spider arm. I replaced the spider arm, which ended up looking fine, and the tub bearings but the issue still persist. I started the washer in test mode and tried to do a spin. It does seem to spin clockwise but then gives a e3e error when the counter clockwise spin starts. I've posted a video here:
From what I've read it looks like it could be one of several different parts that is causing the e3e issue. Before I spend any additional money can anyone tell from the video what the actual issue might be? Also, when I run just a spin cycle with nothing in the tub it just does a little jerk here and there and the time never decreases.
Thanks in advance
Thanks in advance
