FIXED Samsung WF395BTPAWR/A1 Washer creaking during spin cycle
MattZ
Poconos
WF395BTPAWR
Samsung
Samsung front loader starting making this creaking noise during spin cycle recently (see video)
https://photos.app.goo.gl/GKWNCg9c8tBj6nTX6
The machine seems to operate fine despite the noise. No error codes and the cycle finishes in a normal amount of time.
it seems to happen most prominently during the medium spin speed and actually goes away during higher speeds. The sound does not appear to be coming from the suspension springs. shock absorber or am I way off base?
Added complete model number
Hi Matt,
WF395BTPA is just a partial model number, we need the complete model number. The model number tag is located inside the door.
Sounds like the shocks are giving out. When did this noise start happening? Just the last few days?
MattZ
Poconos
Thanks Jake,
Full model is WF395BTPAWR/A1
Quite frankly, it's probably been like this for a month or so now
Thanks Matt!
I'd first physically examine the shocks.
The shocks do not have a lot of resistance on them. They should move fairly easy on the unit, but should not be very loose. They shouldn't be bottoming out or leaking any oil.
Here's the shocks for your model you can order if needed(Each sold separate):
Shock Absorber DC66-00470A
Video included in part link.
MattZ
Poconos
Could use an expert's advice here....
I'm in the process of replacing the rear shocks. I was able to get 1 installed with some difficulty. For the other, I have the new shock in place and the bottom bolt loosely fastened. I can get the top bolt through the bracket and bushing but can't get the threads to catch on the back side. Looks like there's a threaded metal insert but it must be off by a mm or so. I had similar difficulty on the other side, but got it after probably 15 minutes or so. I think I'm going on about 2 hours with no luck on the right side. About to throw in the towel and get a new top loader
MattZ
Poconos
upon further review, the bolt isn't making it to the insert. The barrel of the bolt is getting hung up on the plastic part of the bracket. Gotta figure a way to file/shave the hole I guess.
Ok Matt, You got these shocks at RepairClinic? You watched the video right?
You shouldn't need to file/shave the hole.
MattZ
Poconos
It all worked out in the end. The install issue had nothing to do with the shock itself. I couldn't even get the original bolt through the back hole with the shock removed. The tub polymer was somehow deformed, probably from all the erratic movement of the tub over the last month or so. A little filing of the hole and it went back together. I probably spent 4 hours on the right shock alone when it should've been a ten minute job, but I won in the end.
Ran a few loads and the creaking is mostly resolved. There's still a little that appears to be coming from one of the top spring mounts, but it's much better for now. Thanks for the quick replies and help, Jake.
Excellent Matt, good job.(y)
