FIXED Samsung WF425200AP/A2 Washer not draining
Wallers
WF42H5200AP
Samsung
Good day all. I am in search of wisdom. I have a Samsung WF425200AP/A2 washer and it will not drain and run through the spin cycle. We took the machine apart and found a vent hose plugged. We cleared the stoppage. We ran the machine on "quick" load (its less than 20 minutes) and it ran fine. No issues. The next load and every load after failed to drain. If we unplug the drain at the bottom of the machine an drain the water into a bucket everything seems to work. Is there a way to test the pump itself to make sure its indeed working properly? I did notice the valve/flapper in the pump housing was difficult to open. Could this be an issue?
Edit - Code 5E
1. We can hear the pump turn on.
2. We double checked all hoses and we could find no more obstructions.
I searched on this forum and didn't see anything that was a match to what I was experiencing. If there is something that i missed please send me a link. I don't want to reinvent the wheel. Also, if there is a service manual that I can read that would be handy. I think it's going to be a long road with this machine.
Any help would be appreciated.
Wallers
Hi Wallers,
You will need a multimeter to see if your getting 120 volts to the drain pump electrical connector when it should be draining.
There is a video in the part link to show you how to access/replace it.
Wallers
Jake, I want to make sure I check all potential possibilities before I invest more money into the machine.
I will test to make sure I'm getting the 120VAC to the pump, go from there.
Thanks for the help
What was the issue Wallers?
Excellent Wallers, glad to hear the new drain pump fixed it.(y)
