kng878
- WF45K6500AV/A2
- Samsung
- 6-10 years
Hi All,
Recently tried to turn on my samsung washer and no power is going to the unit. The unit does not "click" when you hit the power button. (Im assuming the click kicks in the washer inverter board)
1) Tested EMI Filter - Read out for input and output was 122 volts
2) Accessed control assembly - tested wires. Reads out 5 volts and 12 volts. (Tried the power on control wire - it should read 3.3volts but I got 5 volts - could be because not same model?). Pushed power button, DC volt went back to zero
3) Tested main board - 120volt AC going into board. Mainboard output to sub PCB also read 5 volt and 12 volt respectively. Again, power on command 3.3 volts reads out at 5 volts.
Any suggestions?
This is what I followed:
Any suggestions?
