SCA1001HSS03 GE fan and light always run with door shut
Bambam0791
Phoenix, az
SCA1001HSS03
I have a GE SCA1001HSS03 microwave that all of a sudden the fan and light stay on the entire time the door is closed. Everything else works perfectly. Tried replacing all 3 door switches and still the same. Ideas what else it could be? Thanks
Door switches, door switch mechanisms, door key are the most common trouble makers.
If these check ok, the smart board is then suspect.
LINK> http://www.applianceaid.com/component-testing.php
Lets hope it is not the smart board as that is coming back as No Longer Available :(
Bambam0791
Phoenix, az
Could you please explain the “door key” and what about the switch mechanism to look for? Doesn’t sound like either of these are electronic. Thx
Door key is the part on the door that goes inside the unit to activate the door switches.
Door switch mechanisms are the pieces inside the door key pushes/pulls/contacts to activate the door switches.
Bambam0791
Phoenix, az
Okay, that all checked out good. Any other switches or limits that could be bad causing this since the smart board is not available anymore? Thanks again.
*If* all checks ok, smart board is only item left = happy shopping time!
