FIXED SCB2001KSS02 Advantium 240 with broken door hinge spring
jp_buyitol
Franklin, TN
I understand this is a 2019 post but there is not much info out there on door hinges for these ovens so if anyone else finds themselves landing here in search of a replacement door spring for a GE Advantium 240 oven (my particular model is a SCB2001KSS02), I too have ordered some custom replacement springs both left and right hand and should have a few spares to sell around the first of April 2020 if you are in need. This should keep you from having to search out a supplier and buy more than you need. I will repost after installation and confirmation that the custom springs did in fact solve the problem with the broken and now discontinued spring assembly. Thx.
jp_buyitol
Franklin, TN
Update to my post above. The replacement springs arrived today and problem solved. I don't think they are quite as stiff as the originals but definitely better than trying to operate the oven with a broken spring. If anyone comes across this and needs either side, I have several extra of each I will ship to you anywhere in lower 48 for $50 ea.
