FIXED Sears Kenmore 665.13223N410 Not Draining
tabs0096
Mississippi
665.13223N410
Kenmore is not draining. Replaced the drain pump, but it still does not drain out the water. The tubes are cleared of all debris, it is clean from end to end.
Yes, pump is getting the proper voltage and yes the pump spins and starts spinning the water
*If* there is no restrictions, *If* the drain pump is getting power and running but no draining is occurring, the new pump may be faulty and should be sent back.
whirlpool-pump-drain-wpw10348269-ap6020066_01_m.jpg Drain Pump
Things like a chunk of plastic, bandaid, glass can act like a check valve and flip-flop back and forth blocking and not blocking. Blowing air through something doesn't mean much if water makes something flip and then the hose is blocked off.
tabs0096
Mississippi
Dead on! Stuck my finger in the tube and felt a sliver like a hair. pulled out a tiny piece of plastic ran a drain cycle. WE'RE GOOD!
Thanks so much for the help Jeff!
