HappyCamper
- 253.8195610
- Sears Kenmore
- More than 10 years
Kenmore Coldspot Chest Freezer 253.8195610
Manufactured 1989
photos.app.goo.gl
First Post. I appreciate any help very much.
I have a large chest freezer that was defrosted a couple weeks ago. It warmed up yesterday when the compressor/ motor started making a lot of noise and outside of the box was cool. I replaced the start relay and it smoothed back to normal and started very slowly cooling again. Outside of box is warm now as it should be. I thought all was good, but there's a cylinder on the right of the compressor that is occasionally buzzing and other times quietly cycling. I don't remember hearing that, but I also had the cover plate on before, perhaps dampening the sound. I can't find a schematic, so don't know what this part is.
It is a brass cylinder in a rectangular case with one electrical plug and gas tubes connected on the bottom.
It's scratched so I can only make out the two lower rows of numbers.
L16 701-038
8850 01
photos.app.goo.gl
I'm wondering if it needs replaced too and what the chances of it going at the same time?
I also want to find a low cost back up for the relay in case it goes bad again.
This low cost combination part https://www.amazon.com/dp/B00A8O071...c1102a3ec4a06&language=en_US&ref_=as_li_ss_tl
sound attractive, but if you have an affiliate link, I will check that out and probably go that route.
Manufactured 1989
New item added to shared album
L16 701-038
8850 01
