Sears Kenmore Dryer 110.96281100 Won't Start
Triple BB
Casper
Today my dryer wouldn't start. When I pushed the start button, it made a humming noise like the motor was trying to start but the drum wasn't turning. I pulled the front panel off and cleaned out all the lint. I put it back together and it started right up. Then my wife pulled the dry clothes out and put a new load in and it did the same thing. I pulled the top and spun the drum and it started up. Later on, she went to start a new load and when she pushed the button, it did nothing. There was no humming noise or anything. I happened to have a new thermal fuse, so I put that in just to check and that didn't help. I know when it was running it seemed to be heating fine. Any help would be appreciated.
Its possibly the motor went out.
A test to see if the motor is any good, hook up a test cord to terminals 4 & 5 on the motor(THEY SHOULD BE LABELED M4 & M5 OR 4 & 5) , plug into a 120 volt outlet to see if the motor will run.
Make sure you unplug the dryer first before accessing and testing the motor.
Here's the motor for your model:
Drive Motor 279827
