Sears Kenmore Elite microwave 401.88523011, Door Assembly DE94-02053C installation
cmesser
California
Is there an installation guide for the dual hinged Sears Kenmore Elite microwave 401.88523011, door assembly part number DE94-02053C?
Ok I figured out how to remove the old door.
I opened the door and with a small right angle pick closed the cams on the open side and pressed the little button near the hinge a the same time to make it latch. Then just pulled the other side open, door is off!
On the new door make sure one side of the door cams are open and the other side are closed. Put the door on the side with the open cams. I think I had to mess with the buttons near the cams to get it to latch then Using the right angle pick I opened the cams on the other end of the door and then closed it. Door is on!
Now I need to figure out how to adjust it.
